SailNet Community - View Single Post - rub rail
Thread: rub rail
post #14 of Old 09-02-2009
Stiche
Custom Member
Stiche's Avatar
Originally Posted by CdnSailer View Post
I picked up my Rub Rail for my '68 Cal 28, from Hamilton Marine in Searsport Maine. They stock the Cal 34 RR but they had mine shipped in. I have also been searching for the mounting directions for the Rail. My existing one on the boat was not screwed in place. It appeared to be dogged into grooves on the deck and hull connection. This may be the correct approach and I may need to apply an adhesive before snapping it into place. If this is the case, can I get a suggested adhesive?
I need some help on this one.
I just replaced the rub rail on my Cal 25. Same issue as you- not screwed in place. If the lips are perfect, then tension should be enough, assuming you have anchors at the stern to hold each end. But since mine were long since worn in many places, I applied 3M Marine Adhesive 4200 FC top and bottom at the bow, and top only on the sides. Works great. Used one caulk tube for the whole thing.
Stiche is offline
