SailNet Community - View Single Post - Which electric fuel pump to add in series on a M5411
post #2 of Old 09-08-2009
JimsCAL
JimsCAL's Avatar
You can't put the two pumps in series, but you could put them in parallel so either could operate. If you go to the trouble of adding an electric pump, just bypass the engine driven one and use the electric all the time. Any fuel pump suitable for diesel should be fine. Go with a low capacity as the 5411 is only 11 HP.
Not sure why you seem to be needing to bleed the fuel system so often. Only had to bleed my 5411 once in 20 years.
JimsCAL is offline
