SailNet Community - View Single Post - Question about boom height
post #3 of Old 09-10-2009
Faster
Barry's spot on.
You need to be sure your topping lift is slacked once you've hoisted the main to the correct luff tension. If at any time while sailing in normal breezes you notice the topping lift get taut, loosen it a bit til it's slack.
In the lightest air you can use the topping lift to support the boom when the boom weight distorts sail trim, removing the desired twist. This can be a problem when tacking as the topping lift will chafe/interfere with the leech from time to time.
Faster is online now
