Originally Posted by smackdaddy
I'm off to install a shiny new holding tank - purchased right here on Sailnet - on the esteemed S/V Smacktanic.
Then, I'm going to proceed to do unspeakable things to it.
Wish me luck chums. This could get messy.
Smack,
I know you are new to sailing and all that, so I just want to help you out. Make sure you do not allow any tubes to vent that tank. It may come with small tube which some cheaper manufacturers run outside the boat. But the proper method is to totally seal it up so no air can get out.
Now, when you go to use the head next, it will be a little hard to pump. That is because the tank is new. It has to be broken in a little. The best thing to do to use the head until you cannot pump it anymore, then get a high amperage wet/dry vac and shove the output into the toilet bowl. You will hear a slight gurgling and creaking from your new tank. This is normal. Just leave the hose in the head on high and go take the deck cap off. Don't forget to smile as you do so because you have just finished your first major boat project!!!
Report back when you are done.
- CD
