I turn the key and no response
The key switch would be the place to start. You should be able to measure voltage on at least one hot lead. Mine has two hot leads. The key switcvh can go bad mostly because it is exposed to some weather.
After that just about anything can be wrong, but no noise or anything would seem to be a bad connection in the key switch or it''s hot lead.
