SailNet Community - View Single Post - I turn the key and no response
post #3 of Old 09-14-2005
Hello, we just had the same experience. Check to see if you have power to the ignition switch, then trace the wiring back to the engine. You should have a circuit breaker somewhere in between.....check to see if it is tripped. Good Luck!
Veranda is offline
