SailNet Community - View Single Post - Pearson 30 Rudder Repair
post #6 of Old 09-16-2005
windship
Drill and tap a hole in the top of the rudder post to fit an eye bolt so you can tie a line to it, then drop the rudder if it is solid? You can then use the same rope to lift it from the water with the boom.
If the rudder is foam filled, weight it down so it is near or at neautral buoyancy.
windship is offline
