SailNet Community - View Single Post - Must have Tools
Thread: Must have Tools
post #5 of Old 09-18-2009
jjablonowski
jjablonowski's Avatar
Accessibility is important
For tool boxes, I like plastic organizers with see-through lids with clasps. SortMaster.jpg
Can't rust. Open it, take out a tool, immediately lock it closed so it can't spill.
Small enough to stow anywhere. Not expensive; get several.
Other thoughts:
- Put a wrist strap on your drill. Davy Jones has an appetite.
- Toss the electric soldering iron. Most here will argue that crimped wiring connections inside a hot-melt-glue-filled connector are the way to go. Get a butane-powered mini torch to melt the shrink-wrap tubing.
- Forceps.
- Waterproof grease. For O-rings, hose connections, etc.
- Dental pick(s).
- Tef-gel or some other anti-seize goo.
- Small magnet, to test for stainless vs. conventional, i.e., rust-prone, steel. I was amazed to find P.O. had installed a couple of non-stainless cotter pins.
jjablonowski is offline
