SailNet Community - View Single Post - Question : Install New Engine vs Rebuild
post #4 of Old 09-18-2009
jrd22
Courtney the Dancer
jrd22's Avatar
Unless you replace the engine with the exact same make and model you will more than likely have to remove the old engine mounts and glass in new ones. You also want to check if the rotation will be the same or else you need a new prop. Exhaust, water intake, etc, etc, may have to be modified/changed depending on location of things on the new engine. A lot of people have reported that the cost of installation has equalled the cost of the new engine.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
