SailNet Community - View Single Post - Another way to cleat
post #5 of Old 09-21-2009
AdamLein
AdamLein's Avatar
I've tried that method and all the concerns are mostly well-founded. If you manually adjust it so that both "legs" of the eye take the load equally, then it's impossible to release under load. And yes, you do have to manually adjust it.
On the other hand, is there any way to put an eye on a horn cleat so that you can release it under load? By "load" I mean enough tension that you can't create any appreciable slack in the line by applying a force perpendicular to the line.
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
