SailNet Community - View Single Post - Atomic 4 Engine Quits
post #3 of Old 07-02-2001
Tao
Sounds like RichH is on to something.While I am not familiar with your particular engine,I am familiar with the problem.The symptoms you describe are exactly the symtoms of a bad condensor in an ignition circuit.If you have electronic ignition the equivelent will be in the little black box.If your running times before quitting is getting shorter,check it out.It could die permanantly at any time. -just my 2 cents-
Tao is offline
