SailNet Community - View Single Post - Dripless vs Flax Stuffing Boxes
post #6 of Old 09-23-2009
Faster
We've had both... installed a PYI dripless on a boat with a V-drive - appreciated the feature given the almost impossible access to the SB below the oil pan. It worked fine, but anything that disturbs the sealing pressure from the bellows will allow leakage. If you plan to do in-the-water gearbox changes, or engine removal be sure to take precautions to avoid unloading the seal - it will leak very well indeed!
Faster is offline
