SailNet Community - View Single Post - Yanmar 3ym20 pre mature water pump failure
post #2 of Old 09-30-2009
nuffoftexas
nuffoftexas's Avatar
Originally Posted by jbrockpiano View Post
I have a 2 1/2 year old 3ym20 with about 400 hrs on it. After returning from a six week cruise I found the raw water pump leaking. I thought it was the hoses but it turned out to be the bearings in the pump itself. This seems to be a bit early for a water pump to give up the ghost. Any one else have this problem ?
Depending on where you are located, the type water and solids in the water, and also winterization techniqes, raw water pump assemblies and impellers may need service every year. If I didn't replace the impellers on mine every spring, it would surely need replacing at the most inconvenient time later that year.
nuffoftexas is offline
