SailNet Community - View Single Post - Cal 25-2 Rigging
post #2 of Old 10-01-2009
bfabian
Hi Thomas,
I, too, recently bought a 1978 Cal 2-25! I've had her since July of this year. Your boat sounds very similar to mine with the winch on the port side. But, I have a boom vang. However, I'm not sure if it was originally with the boat or the previous owner put it on. I'm the third owner of the boat.
I've recently had a problem with the spreader on my starboard side. I was hearing a pretty significant clanging sound when I was on a port tack the last time out. When got back to the marina, I found that my starboard spreader was very loose. I went up the mast today and determined that the loose spreader was angled down at about a -5 degree angle from the mast while the other spreader that is ok was angled up at about 5 degrees off the mast. Can you confirm for me that both spreaders should be angled off the mast or should they be perpendicular to the mast?
Thanks,
Brian
bfabian is offline
