SailNet Community - View Single Post - Teak inlaid cockpit seats
post #3 of Old 10-01-2009
MJBrown
October Moon B43
I had the same thing happen on a Benny 361 we had. If you catch it before the teak warps too much they're easy to fix. First make sure it dries out underneath the teak. You wont want to seal moisture in. I just waited for a week that was warm and dry. Take a sharp knife or blade and cut away the old caulk that surrounds just the area that has lifted up. Clean the area as best you can. Then use black silicone sealant to re-seal the area in mention. I used a couple of gallon bottles of water to sit on top of the teak to keep it pressed down. I left it there until I was sure the sealant had set up. I did it on a warm sunny day and it turned out just fine. The biggest problem is laying the caulk down in a neat bead. I'd have some acetone handy in the event you get some sealant where it doesn't belong. Good luck.
Mike
MJBrown is offline
