SailNet Community - View Single Post - hard dodger vs. soft
post #12 of Old 10-01-2009
imagine2frolic
imagine2frolic's Avatar
Not to disrespect your thoughts Faster, but it can be a big issue. As I typed it is rare, but it does happen.
On the hook we got a quick squall come through on the Halifax river. It topped out at 60 knots. Unfortunately the frame wasn't through bolted by the builder. This squall only lasted 20 minutes, but it tore the front of the frame loose from the house. Now we had a flat panel at about 30 degrees to the wind. Only the boom was holding it down.
Unfortunately the builder ran the frame through the cloth. I had to cut the bimini to shreds. The new bimini is now laced, and the lacing can be cut to save the bimini. The frame is now through bolted, so it will be nearly impossible to be pulled loose. It was windage that broke it loose while throwing in some bad design flaws.......i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
imagine2frolic is offline
