Old 10-01-2009
SanDiegoChip's Avatar
SanDiegoChip SanDiegoChip is offline
SanDiegoChip is on a distinguished road
We have a Perkins 4108
We have a Perkins 42108 and I was told the engine it’s self will run for almost ever. It is all the parts attached to it that fail. Ours is 30 years old and has lived in a dark damp place. We recently had and injector clamp fail, it just broke sitting there in the boat not even running. When I started the motor smoke came billowing out and it sounded like it through a rod. Any way I fixed it with the help of a dock mate. I did notice the fuel line to the injectors was a bronze or brass tubing brazed. Now when is that going to fail? It sure is hard to think of replacing a perfectly good running engine. We are going cruising in a few years so there is the rub. I would leave it alone and still might but for leaving the country and when we need it we may REALLY need it. No vessel assist to call.
The PO set up a fresh water rinse for the cooling. It draws water from the fresh water tank instead of the sea water, flip a valve. OK I have not tried it yet but it seems like a good idea. We have had the boat six months.
