SailNet Community - View Single Post - Different types of Cutter rigged boats
post #2 of Old 10-04-2009
krozet
Waiting For Spring
krozet's Avatar
Originally Posted by delecto View Post
Ok so I understand how a normal cutter rigged boat has both a jib and stay sail furling system. But I'm looking at some boats on yachtworld that appear to be modified Sloops that have a removable staysail wire where a stail sail can be attached to it. My questions are: (1) How is the staysail attached to the wire and how is it deployed? (2) I'm assuming that the masts on these boats are set up for Sloops (ie: further towards the bow), so how does that affect the rig compared to a normal cutter that has its mast in the center. (3) Is this a healthy alternative to the traditional cutter rigged boat?
I can answer one of these... From the cutter rigs that I have seen (that do not use a second furling setup) the Stay sail would be hanked onto the wire.
1971 Contest 33 Hull Number 24
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
Mark Twain
krozet is offline
