Guys, Guys This is a 2 min. check.
First make a continuity check of the wires going to the sender at the plug.
If no continuity, stick straight pins in the wires at the sender as close as you can and check for continuity again.
If you have continuity at the pins than the wire is bad.
If you have continuity all the way to the plug then the sender is ok but the wheel is not spinning.
If you have the sender out you can spin it and you should read pulses at all is well at the connector.
This is best checked with an analog meter because sometimes digital meters will not read pulses.
Rick To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
