SailNet Community - View Single Post - Lost Rudder
Thread: Lost Rudder
post #9 of Old 10-07-2009
JomsViking
Splashed
JomsViking's Avatar
On most boats the rudder should be light with neutral buoyancy - it should neither float, nor sink, so letting water into it seems like a bad idea? When it is completely enclosed, there's also the risks of corrosion.
Not trying to slam your product, just sayin'
And.. consider paying for an ad on Sailnet
Originally Posted by stainlessoutfitter View Post
Stainless outfitters up in barrie Ontario have had quite a bit of success fabricating new rudders in stainless steel.They are the exact shape as the original and fully welded where the shaft enters the rudder.Completely sealed it is very light or ballast it with water which you just drain out at the end of the season. Built like an aircraft wing and skinned with 14 gauge stainless plate, they cost no more than a new fiberglass rudder.
Watch great footage about the story of one manís slow odyssey around the UK:
JomsViking is offline
