  #16 (permalink)
Old 10-10-2009
PalmettoSailor PalmettoSailor is offline
PalmettoSailor will become famous soon enough
Originally Posted by Northeaster View Post
Midlife - I believe that the strut-prop, or similar devices, only work on boats that actually have a separate strut that holds the cutlass bearing. On the OP's boat, the cutlass bearing is mounted inside the hull itself, so you do not have access to the forward end of the cutlass bearing. The strut-pro device lets you squeeze the cutlass in, while still having the prop shaft in there as well, but would only work on boats ( the majority nowadays) with struts.
I understand that and mentioned it in a previous post. I was just pointing out why there is such a tool in response to a post by someone that had a boat designed for uncomplicated prop strut removal. That aint the case with a lot of boats.
PalmettoSailor (formerly midlifesailor)
s/v Palmetto Moon
1991 Catalina 36
