SailNet Community - View Single Post - Holly grail for new teak!
post #3 of Old 10-14-2009 Thread Starter
wakesurfboy
Originally Posted by JohnRPollard View Post
Are you talking about interior or exterior teak, or both?
Personally, I would not coat teak with epoxy. Clear (i.e. unthickened) epoxy is used as an impermeable sealant, to protect wood from water damage. Teak doesn't need protection from water -- it is already virtually impervious to rot because of its natural oils.
Also, the epoxy will need to be protected from uv damage at all times. If you ever miss a re-varnish cycle and the epoxy suffers uv damage, you will have a real mess stripping it all off.
I talk about the exterior of course. Interior is already protected and less exposed to weather (sun & water).
About Varnish, can I absolutely trust this solution and only have to sand a bit each year and put 2 new coat? I fear the varnish will peal after a while even if I put two new coat each year... In fact, too much varnish will make the full coating too thick, I presume?
Also, because teak is oily, that makes varnish less grip?
wakesurfboy is offline
