SailNet Community - View Single Post - liveaboard home theater
post #17 of Old 10-14-2009
JeffBurright
JeffBurright's Avatar
If you already have a home theater setup mouldering away in a box, I'd say go with the cheap CPU approach. Although, I think the question really is whether you intend to use the theater while you're out cruising, or whether it's more a dock-side attraction. If it's the latter, I wouldn't worry about the amperage or dc vs. inverter question, since it sounds like any of your CPU or PS3 based solutions would draw a substantial amount of power anyway and you might as well just plug them into the dock.
If you intend to watch/play while out on the water though: 1) Are you nuts? You're in the wild blue yonder! ; and 2) I'd take the laptop route since it solves the DC problem for you and you could still game on it if you get one with a dedicated graphics card. Plus it's easier to stow.
For my 30'er, I actually got rid of an AC/DC tv/dvd player since it seemed too old fashioned for my purposes. Now I'm rocking an older dual-booted Imac with the stand cut off and mounted in the v-berth, so that I may blow my enemies into tiny bits (TF2 ftw) or curl up with Hulu while at the dock or via inverter in a pinch. I also picked up a netbook to do my casual work and surfing from the salon table, or to act as my chart plotter when I hook it up to the GPS. It works for me, but you may have grander ambitions. Good luck either way and let us know if you devise the perfect setup.
JeffBurright is offline
