SailNet Community - View Single Post - Rebedding aluminum toe rails
post #8 of Old 10-15-2009
mitiempo
mitiempo's Avatar
The bolts should be tightened when the caulking is put on, not later otherwise you run the risk of breaking the seal you're trying to create if a bolt turns on set caulking. Don't listen to Casey on this - he's wrong.
Brian
mitiempo is offline
