If you bed the bearing on epoxy, removal is easy.
If it's in a metal carrier just heat the metal and the epoxy softens, it slides out as it is a clearance fit. If it's in grp with a release agent you can split the joint and it will slide out.
No need for presses, pullers or hammers.
