SailNet Community - View Single Post - liveaboard home theater
post #20 of Old 10-17-2009
wind_magic
Nail,
I use a nano-ITX board w/ 12vdc power, works great, runs Linux just fine. The board I use is extremely low power, but they make them even lower, there is one nano-ITX board out there that is about 6 watts and doesn't even require a fan, it just has a heat sink, so you can hide it away in whatever enclosure you want to use. Simple enough to add IR sensors so you can use a remote control, though I have not actually done that (yet), high resolution video, enough to drive my display at 1280x1024, ether, etc. Combine it with a solid state drive and it is very, very hard to kill.
Edit, also, I would use an external drive, because the drive ends up using more power than the ÁP.
Edit #2, and I did manage to kill a power supply, but I have lots of radios and sensors hooked up to my ÁP so things like that happen sometimes. Now that I have installed reverse polarity protection on all of my circuits I hope I won't cause myself any more problems.
Edit #3, before you commit to a display, you might consider looking around, I found a display that is 12vdc with an external 120vac supply. I use a dc-to-dc converter for that and it works great, my entire setup is now 12vdc and doesn't require an inverter.
What are you pretending not to know ?
Please support my
wind_magic is offline
