Water hose
Danielle - I haven''t seen the problem but from here it sounds as if the hose is too large or is old and hard. The hose should be difficult to push over the nipple that you''r connecting to, usually requiris a lot of effort or warming the hose to get it on. Usually there is a raised (bump)on the pipe your connecting to, the hose clamp goes behind the bump and won''t slide off. If the hose is so old and hard that the clamp can''t squeeze it down then it won''t stay on.
It''s hard to say what your problem is without being there, I''m guessing that a new hose of the proper size is needed.
Dave
S/V Windsong
Pearson 35
