SailNet Community - View Single Post - UV Protection for Roller Furled Genoa
post #8 of Old 10-18-2009
sailingfool
ASA and PSIA Instructor
Originally Posted by countrygent5201 View Post
I read a little about this last night but figured that an adhesive strong enough to withstand the rigors of sailing would be impossible to remove or replace. Does this stuff actually work? Is this something I could do myself? Where could I go to learn about installing it? Thanks for all the good advice.
As tyhe material degrades due to UV wear, it the adhesive starts to soften also. ends up being not to hard to pull off, after 5=10 years of use. Again, the sailmaker will have all this dowe pat,you should use one.
sailingfool is offline
