  #13 (permalink)
Old 10-21-2009
sailingdog sailingdog is offline
The real problem with this as a solution is that it uses a lot more power than using a dedicated bridge, like the Ubiquiti Bullet2 HP and a micro Wifi Router, like the D-Link DWL-730G AP, and it requires that your computer be on all the time.
This also leaves you with some security issues, in that your computer is now acting as a bridge or router effectively, depending on how you have it configured... sharing the WiFi connection from the USB device to the router.
Originally Posted by Thadius123 View Post
Thanks for the information. Rather than purchase a bridge I would rather just keep my existing USB antenna and effect the bridge between that and the router with the notebook. Obviously my existing USB antenna (built-in hardware) would be incompatible with any bridge I would purchase and necessitate the need to also acquire an external stand-alone antenna.
With regards to the actual bridging in the network configuration control panel are there any potential hardware conflicts that I should be aware of?
Would I expect to see any sort of signal or quality degradation with respect to my average speeds I reported earlier with such a network setup?
Thanks for the reply as it was very informative.
Cheers!
