SailNet Community - View Single Post - Re-install the marine air or keep the window shaker?
post #4 of Old 10-22-2009
deniseO30
One of None
deniseO30's Avatar
Mike that sounds wrong.. you sure you didn't read the LRA? (locked rotor amps) 12,000 btu should be well under 15 at 120 volts. the pump motor would be fractions of an amp most likely.
I just looked it up! 53 is LRA, 35 is the max breaker size min breaker is 20 amps. FLA is 10 amps for cool and 12 for heat mode. I"m sure this is close to what you have Marine Air VCD12K/2 12000 BTU 115 Volt Boat Air Conditioner
My last project!
deniseO30 is offline
