Old 10-24-2009
CalebD's Avatar
CalebD CalebD is offline
Tartan 27' owner
CalebD will become famous soon enough
Start thinking outside the proverbial 'box'. $300 sounds pretty cheap by the way, especially if that is for materials for replacing ALL the rub rail at one time.
Stuff that is marketed to mariners is way overpriced. You could use a material marketed for a chair rail (as in mounted on the wall) in office buildings or you could even make something better out of a length of old fire hose. Used fire hose has an intrinsically nautical look and is extremely durable for this application, even if painted.
Some people even use 'Pool Noodles' for rub rail on their dinghies.
If your epoxy/fiberglassing skills are up to it you can find many ways to repair such shortcomings.
If you do not want to replace the whole rub rail then consider getting some 3M 4200UV or other putty that might include: 3M 5200, Marine Tex epoxy etc. and make a mold for it out of empty plastic milk bottles that will peel off eventually. Get creative. I like the fire hose idea as it is very durable and used as chafing gear on commercial vessels but if left raw it will scratch some surfaces. There are Polysulphides which are more like rubber in consistency and even Butyl tape which is easily scraped off and replaced.
If you want to try 'used fire hose' just search for it on ebay.
I have a 25' section in the trunk of my car that I am certain will come in handy for chafe protection somewhere along the line.
Some of your choice will be dictated by where you sail (Lake, Sound, Great Lake or Ocean) and how good you want it to look when done.
You need to experiment and get away from the marketing experts that seem to run the WWW. It is 'free' marketing for them so that is why it is 'free' to you and me.
Used tires would also work but look crappy.
