New Depth Sounder - No Reading?
This past summer I tried to install a Hawkeye Depth Sounder in my 1971 Ericson 29. Wiring and everything is fine, the unit is getting power and I know works as I hear the clicks when I hold it to my ear. I am trying to test install it by bedding in petroleum jelly against the forward hull very near the centerline under the V-berth.
I can't get a reading?!? I have tried a couple locations there and no difference. Whenever I turn it on all I get is zeros which means no signal returned. Any ideas on what I can try? I don't want to install it on the transom if I can avoid it. Is Fiberglass too thick?
You will regret the things you did not do, more than the things you did.
Get out there!
Saco Bay, Maine
1971 Ericson 29
