SailNet Community - View Single Post - Advice on this Cat 30
post #1 of Old 10-26-2009 Thread Starter
xbalancex7
I was on this boat today and I have not sailed it yet. but I'm looking for a liveaboard and I really enjoy the feel of this boat. I have about 10k available and asking price is 14k. what are your thoughts about it? anything specific to look for on this model cat? thanks and let me know.
My 10 year plan is a coastal cruise from SF down to mabye coasta rica who knows in a perfect world maybe through the panama canal, but for now i"m happy coastal cruising SF to San diego. I want the interior space and headroom. any thoughts? Thanks for your time!
listed below are the details on this I believe it was about a 1981ish Cat
Details
Features
• Sleeps 6
• Tall solid rod rigging
• Diesel engine
• Self steering
• Roller reefing jib
Notes on condition
Over all the boat in good shape and I have done the following maintenance recently.
* Two new main batteries
* All new hoses on engine
* New engine starter
* New hoses on sanitation system
* Some new dock lines, and jib lines
* Hull recently cleaned and the diver say bottom is fine
* Took fuel tank out of boat and cleaned it
What needs to be done is:
* reattach the loose weather cover on jib
* New hoses to water tank and sink
* Recalibrate self steering unit
* Patches on 3 seat covers
Details
Type: Auxiliary Sail
VESSEL PARTICULARS
Builder: Catalina Yachts, CA
Designer: Frank Butler
Year Built: 1981
Model: 30’ Catalina Tall Rig
LOA: 30’ 00”
Beam: 10’ 00”
Draft: 5’ 03”
Displacement: 10,500 lbs.
Ballast (type/amount): Lead / 4,300 lbs.
Hull Type: Fin keel / spade rudder
Material/Color: Fiberglass / white
PROPULSION SYSTEM
Type: Diesel
Hours: 450 “by meter”
Manufacturer: “Universal”
Model: M2-12A
#Cylinders/HP: 2 / 12
Year: 1993
Cooling System: Fresh water heat exchanger
Alarms: Yes
Gauges: Full @ helm
Flame arrestor: Yes
Exhaust(s): Reinforced hose
Silencer(s): Can type FRP
Reduction Gear: “HBW” 35-2R
Shaft: 1“ stainless steel
Strut/Bearing: Single leg bronze / Cutlass – slight wear
Propeller: 3 bladed bronze
MECHANICAL SYSTEMS
Eng.Rm.Ventilation: 12v Blower
Insulation: None
Wheel/Tiller: “Edson” SS wheel
Bilge Pump(s)-Manual: “Whale” diaphragm in cockpit
Auto: “Rule” 3500 with float switch
Potable Water-Manual: “Whale” foot pump at galley,
hand pump at head vanity
Head: “Wilcox- Crittenden” manual
Holding Tank: Plastic
Macerator: “Jabsco”
Other: “Navtec” hydraulic backstay and boom vang
ELECTRICAL SYSTEMS
DC-Batteries/Amps: (2) 12v Gp24 deep cycle - new
Boxes: Plastic w/tops straps
Approved: Yes (ABYC E 10.7.1 – 10.7.12)
Engine Alternator/Amps: Est. 50 amps
Charger/Amps: “TrueCharge” multistage / 10
Vapor Proof Switch(es): “Perko”
AC-Shorepower: “Marinco” 30 amp inlet and cable
GALLEY EQUIPMENT
Sink(s): Stainless steel dual basin (Note)
Refrigeration: Icebox
Stove Type: “Origo” 3000 alcohol
# Burners/Oven: Two w/out oven
Tank Stowage: Integral
TANKAGE AND PLUMBING
# Fuel Tanks/Capacity: One / 20 gals
Material: Aluminum
# Water Tanks/Capacity: One / 40 gals
Material: Polyethylene
How Secured: SS strapping Framing
Raw water Strainers: Yes
ELECTRONICS/NAVIGATION EQUIPMENT
Compass(es): “Ritchie”
VHF Radio: “Standard” Horizon
Autopilot: “Raymarine” ST 4000+
Speed Log: “Signet”
Wind Indicator: “Signet” wind speed and wind point displays
Depthfinder: “Signet”
Ship’s Clock: Quartz brass
DECK EQUIPMENT
Anchor(s): (1) “West Marin” (Danforth type) 13#, (1) “Danforth” 20# (spare)
Bow roller: SS
Stanchions/Lifelines: 1” SS / double wire
Docklines: Misc. braid 3 strand
Fenders: Medium pneumatic
Covers: Main sail, winches
Swim Ladder: SS
SPARS, RIGGING AND SAILS
General Condition: Good – A number of upgrades including tall rig, rod rigging and hydraulic backstay and vang have been installed for racing.
Type of Rig/# Masts: Sloop / One, double spreader
Material: Aluminum
Keel bolts: SS – Appear good at heads
Standing Rigging: SS rod
Terminals: Peened rod ends
Turnbuckles/(pins?): SS Bronze / yes
Chainplates/Stem: SS
Running Rigging: Dacron braid
Winches: (2) “Lewmar” 42 (primary), (2) “Lewmar” 30 (secondary), (2) “Lewmar” 8, (2) “Lewmar” 16 (mast/halyards) (Note)
Rigging details (vang/traveler,etc.): “Harken” main traveler, “Norh” roller furler, “Navtec” hydraulic bacstay and boom vang
Sail inventory: Full-battened main and jib (new), main and jib (old set)
SAFETY/REQUIRED EQUIPMENT
Throwable Device: Ring-buoy 24”
PFD’s: (4) USCG Type II (33 USC 175), (2) type III
VDS: “Olin” kit (33 USC 175) (Note)
Horn/Bell: Handheld freon / NA
Radar Reflector: Suggested
Oil/Pollution Placards: Yes / Yes (33CFR151.9)
Fire Extinguishers: (2) “Kidde” 3# ABC dry chemical
xbalancex7 is offline
