  #16 (permalink)
Old 10-26-2009
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Super Moderator
It is not so much that Ferrocement is bad per se, but that it has its limitations. Properly done and used on big enough boats where it actually makes sense then it is a reasonable method to build a boat but never an ideal method to build a boat.
The boat in your link, has much bigger issues than the fact that it is ferrocememt. It is a terrible design in terms of its likely sailing ability and general layout. No matter what material this boat was constructed in, it would be a really poor choice for anything other than a live aboard that you did not plan to sail.
But more to the point, it will cost you as much to buy and upgrade and maintain that boat as to buy and as it would to buy, upgrade and a maintain a reasonably high quality fiberglass boat with a more universally appealing design. In most marketplaces ferrocement boats are simply worth a lot less to a fiberglass or aluminum boat of an equal design and build quality, so on a boat to boat comparason so it will be much harder to get the money back that you invested in the purchase and restoration. It is for that reason, if none other that people are suggesting that you walk away from that particular ferrocement boat.
I did want to touch on Seabreeze 97's point about the durability of concrete buildings and transportation structures. Unlike boats, within reason weight is not as critical factor so in buildings, we can tollerate much thicker concrete as steel protection. Typically in a concrete building any element that in contact with the ground is required by code to have a minumum of 3 inches of concrete over the top of any structural steel reinforcing, and even concrete that is in the air, requires a minimum of 1 1/2" of concreteprotection over the steel. That 3" or even 1 1/2" is a much thicker cover than the typical 1/4" to 3/8" concrete cover over the steel in a ferrocement boat, and that 1/4" to 3/8" cover is for a material that is nearly constantly exposed to high moisture.
But also, because concrete building designs are less concerned about weight than ferrocement boat designs, the margins of safety, on buildings can be and typically are many times higher than those used in designing Ferrocement.
Anyway the following is an article on Ferrocement that I wrote for another venue but which summarizes Ferrocement, albiet a viewpoint that represents a North American point of view. (You might also want to look at the rather long and very detailed discussion on ferrocement boats over at the Cruisers Forum.com. Ferro Cement Hulls? - Cruisers & Sailing Forums Its a good thread with people weighing in on both sides, including a number of people who actually own ferrocement boats. and it includes much of the engineering data that backs up the claim that on a pound for pound basis, ferrocement is the weakest boat buillding material.)
To begin with, simply taken on a pound for pound basis, ferro cement is the weakest of all of the commonly used boat building materials. Ferro-cement operates by the same principle as fiberglass, in other words, a high tensile strength reinforcing held in shape by a high compressive strength, low tensile strength cement. The cement in ferro-cement ideally is a very high strength Portland cement with a very fine sand aggregate. (The cement in fiberglass is polyester, vinylester or epoxy resin.) The tensile reinforcing material in ferrocement is steel (sometimes with glass fiber added). (In fiberglass it is glass fibers or other hig tensile strength materials in a variety of forms, kevlar, carbon and all kinds of new variations on these materials).
Ferro-cement's weight comes from a number of sources. First of all, no matter how small the boat, there is a practical limit to how thin ferro-cement can be. Ferro-cement needs to have a minimum thickness in order to have sufficient depth of cement material over the steel to protect the reinforcement from moisture (the typically quoted thickness of cement protecting the steel varies between ¼” and 3/8”, depending on the source and the cement being advocated). Because of this boats below 40 to 45 feet are generally considered too small to use ferro-cement efficiently. (i.e. their hulls, and deck structures weigh a lot more than they an equal strength structure would in some other material.)
The implication of the weight issue is not readily obvious. At the risk of sounding like a broken record, Weight in and of itself does nothing good for a boat. It does not make it stronger, or more comfortable or more stabile. Weight does increase the stress on the various parts of a boat. It increases the size of a sail plan required to achieve a particular speed. It increases drag and typically means that for a given draft a boat will have a less efficient keel (i.e trading off greater drag for the same amount of leeway.)
In order to carry more sail area the heavier boat with equal or less ballast stability needs greater form stability, which comes at the price or a choppier motion and greater drag, or greater ballast or deeper ballast which adds more weight and drag and perhaps depth.
Similar to steel, to keep the weight down, many ferro-cement cement boats have reduced ballast ratios when compared to other construction techniques. This means that they need more sail area because of their weight but they can't carry more sail area because of reduced ballast ratios, at least not without using lower aspect rigs which are by their very nature much less efficient on almost all points of sail.
This is further complicated by the fact a higher proportion of the weight in a ferro-cement boat is carried in the in the topsides (and sometimes decks). This means a high center of gravity which has a variety of implications; reduced stability, wider roll angles, smaller angles of ultimate stability, and more prone to excitation rolling (which may be slightly offset by the greater inertial moments due to weight).
This added hull and deck weight, larger sail plan, and perhaps greater ballast requirement to carry the sail plan make these boats a less than ideal choice for distance voyaging for a variety of reasons. Any given design can only safely carry so much weight before it begins losing safety, stability and sailing ability. If excess weight weight is required for the hull, deck, rig and ballasting, there is less weight available to carry food, stores and gear. For a given payload, a bigger more capacious boat is required. And since displacement is a major component in determinging the amount of anticipated maintenance costs (affecting sails and deck hardware size, ground tackle and dock lines, engine size and fuel consumption, down to even simple things like the amount of bottom paint required), these boats that can become expensive to maintain as well.
Which then brings us to maintenance costs. In a study performed some years back looking at the life costs of various materials, ferro-cement-cement came out as the second highest maintenance cost material (if I remember worst to best was steel, ferro-cement, conventional wood, aluminum, fiberglass, cold molded wood) Of course as with any generalized study there will be case by case exceptions and given the comparatively small sampling of non-FRP boats the results could easily been skewed by a few bad apples.
Other problems with ferro-cement are the difficulty of connecting things to it, and prevention of rot in wood in contact with ferro-cement. The difficulty in bolting to ferro-cement is that ferro-cement hates localized loadings. It’s hard to glue things to ferro-cement; secondary bonds are greatly greatly weaker than primary bonds.
Then there is the market value issue. ferro-cement does have a reputation in the States that does not match the comparatively high regard that it is held in other countries. Some of this is just plain unfair prejudice but some of this comes from real shortcomings in the materials as noted above. A well-built ferro-cement boat can be a reasonably good cruising boat. But the image of the crudely finished ‘hippie’ built cement and rust buckets still clouds the perception of ferro-cement for many North Americans.
The other problem is telling whether the boat that you are looking at is a good boat. It is very hard with non- destructive survey techniques to tell whether the original work was done well and is in good condition. While sounding will reveal any major separations in the cement to reinforcing bond, it does little to determine the affects of fatigue, poor curing practices or cold joints. With Ferro-cement it is particularly important to maintain the ferro-cement parts in good condtion. That can be very significant. People who buy boats because they are priced well below the market, often are overly frugal or just plain do not have the money that it takes to properly maintain a boat. An otherwise good Ferro-cement boat left to poor maintenance and miss-handling can quickly become a poster child for why North American’s don’t trust Ferro-cement.
To me the real cost of owning a boat is the difference between what you paid for the boat, the cost of upgrades and maintenance and the price that you can get when you sell the boat. The problem with a lot of low value boats is that the sales price is always limited no matter how much you put into the boat. This works against ferro cement boats big time.
I guess my conclusion is if you are strictly looking for a low initial up front cost boat and don't mind putting some sweat equity in, and you can look past the sailing shortcomings, and you actually find one that was well built and well maintained, a ferro-cement boat might work out fine for you. For most of us, they do not.
Respectfully
Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
