Old 10-26-2009
sailingdog sailingdog is offline
You do realize that doing this will probably reduce the output of the Rule bilge pump by over 50% of its rated capacity... Generally, centrifugal pumps, like the Rule, should have as short a run with smooth walled hose and no check valves as possible. The diaphragm pump will act as a set of check valves and cut the output drastically.
You're really better off putting each pump on its own output..... I'd also point out that if you're taking on water, having the two pumps in series means that you're limited to using one or the other... not both... and that might cost you your boat—pennywise and really pound foolish.
