Take data.. hull speed vs RPM. This will show you where the engine likes to run for best performance with your boat and prop setup. I run at 2800, 2900 where the engine is the smoothest. Also with a 14Dx12P prop it is at 60 % efficiency/ 40% slip which is quite good for the narrow 2 blade Martec.
Cal 9.2 #19 SilverSwan
