SailNet Community - View Single Post - Looking for a Boat Inspector....
post #6 of Old 10-29-2009
eherlihy
Learning the HARD way...
eherlihy's Avatar
Wanna' buy a problem?
Originally Posted by Shipislandpirate View Post
Coach roof brow trim..section damaged during haul out... Also, notice a crack in the coach roof approx 16 inches long kinda wanders with no definite start or stopping point..and the top to the v-berth door is warped or misaligned 1/2 inch or more...
These things together lead me to suspect that the boat has had an accident of some kind. I doubt that the hull is true to it's original form.
To check, stand about 20-40 feet directly in front of the centerline of the boat. Look carefully at the hull profile. Is it symmetrical? Now, move 10 feet left, and look carefully, now move 20 feet right (10 feet to right of CL) and look again, do the two profiles seem to mirror each other? Now repeat the whole exercise from the rear. I would also check very carefully in the bilge, in the saloon storage areas (under setees), and the bilge, to look for bent/cracked or repaired stringers. Also look for non factory glass work in the bilge.
If my suspicion is correct, it is unlikely that the boat will track straight (think of a car with a bent frame).
- Ed
eherlihy is offline
