Thread: teak decks
Old 01-17-2006
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Super Moderator
teak decks
It is almost imposible to do a thorough assessment of the condition of a teak deck. leaks into the core can result in rot but the adhesives used can often mask the problem until it is extremely serious. You can remove some plugs to see how much wood exists above the core and some remove some screws, which may or may not show whether is rot in the deck. If core damage is extensive the screws will feel stripped on removal or on reinsertion. It is something of an educated crap shoot as to whether the screws that you are removed are in a damaged area or not.
While the cost of replacing a teak deck will vary depending on the design of the deck and where you are having the work done, discussions of this topic on other bulletin boards suggest that the cost could be in a range between $20,000 and $40,000 depending on the grade of teak and extent of the damage to the core.
The lifespan of teak decks are generally cited as being 20 to 30 years depending on maintenance, sailing venue, and original construction.
For me, teak decks are a deal killer, especially on a boat of this age. If I had to restore a boat with teak decks, I would remove the teak decks, repair the sub-decking and go back with a fiberglass non-skid deck. There is no way that I would consider going back with teak decks.
Respectfully,
