I think that captbillc is getting at a common misconception that you should run a diesel as hard as possible. They do run well when run hard but you don't have to run them at WOT all the time. For this argument, I am going to make the assumption that you have proper gearing and prop pitch so lugging isn't a huge issue.
The real danger to running the engine at low rpm is glazing of your cylinder walls. This is caused by the engine temp being too low when running. If you are worried about glazing, make sure your temp gauge is reading in the normal range and try throttling up for a second and looking at the smoke color. If you see a big puff of blue smoke, your engine temp is too low and you need to throttle up but if you see black smoke, that is not an issue it is just unburt fuel because you are not moving enough air yet. Almost all engines now have a thermostat so they are more forgiving in terms of regulating their own temp.
The danger with running a diesel too fast is related to fatigue and heat. If you run an engine really hard, your exhaust gas temps will go up a lot and maybe even your block temps. Your engine can only take so much thermal cycling before it starts to have problems. Also, the increased rpm means that there are more fatigue cycles on the engine components. When you calculate fatigue, the variables are stress and the number of cycles and you are greatly increasing the number of cycles by running high rpms.
Most diesel engines will get their best efficiency at an rpm just over the torque peak. Some manufacturers will actually post this information, I know that cummins does on some of their engines. This does not take into account your specific boat which may have its own optimum speed. The last consideration is your time value and your wallet, you own an engine for a purpose and you might as well use it to suit your needs.
In truth, to properly answer this debate, you need to look at how everything is setup including hull form, expected conditions, gearing, and prop. For this discussion, I believe that we are assuming that these things are fixed but if you are repowering, you need to start with these variables.
