SailNet Community - View Single Post - a4--starting the rehab
Old 10-30-2009
CalebD's Avatar
CalebD CalebD is offline
Tartan 27' owner
CalebD will become famous soon enough
Firstly, congrats on wanting to roll up your sleeves and get your ol' A4 ticking along. You don't say what symptoms it is having that make you want to do this procedure. I'd also highly recommend you join the Moyer Marine A4 forums as there are many hands on owners over there who will not flame you for having a gas engine on your boat. Moyer Marine Atomic 4 Community - Powered by vBulletin
I have a 41 year old A4 and can tell you that MM is by far the best A4 resource on the web besides CardiacPaul (a member here) who will likely give you good advice and flame you all at once!
Your list was:
1 pull plugs (got new plugs? Champion RJ12C or better Autolite 437)
2 couple of shots tranny fluid in each cyl. (why tranny fluid? Use Marvel Mystery Oil instead and squirt it away from the manifold to lube the valves)
3 pull coil wire (pull wire coil? yes. New ones aren't expensive - Napa)
4 old towel over top (that is kind of sweet! I love/hate my engine too.)
5 bump ignition to get it movin (you did replace the plugs right?)
6 drain fuel bulb (you would do yourself a favor and get rid of all the old fuel and start with some fresh fuel. Do you know how long that fuel has been sitting around?)
7 wee bit tranny fluid in fuel bulb (again, not tranny fluid - Marvel Mystery Oil)
8 bump ignition (again?)
I would add (in no particular order):
- check or change water pump impeller
- change fuel filters, you should have a water separating filter
- change oil ASAP (Rotella T sae 30 is very good)
- replace ignition wires (firing sequence 1,2,4,3)
- replace distributor cap & rotor
- points or electric ignition?
You should be able to get most of these parts at a good auto parts store but Moyer sells all of the correct items at a slight premium. It is worth it if it saves you from running around or if you are not sure about what you need.
My best.
