The 31 is it!
I sailed all 3 before deciding the 31 would be my boat. In my opinion the 31 sails better on all tacks except perhaps a dead run, probably as a result of the canoe stern on the others. I do know that I could sail faster than a 34 on beats and reaches, even though the 34 has more waterline. I actually like the motion better on the 31, also. I did mostly single handing and you can single hand any of them once at sea. But, the stuff is smaller on the 31. It is easier to get the sails up, trim, weigh anchor and so on. The head aft is an important feature when cruising, I think. It allows you to duck below quickly and not drag wet clothing through the whole boat. When coming into a dock, the 31 is much easier to maneuver and get some lines over, when you are alone.
If I were going around the world I would want the 40 for size, stowage, water, fuel. Other than that, I believe the 31 is the best coastal cruiser.
Larry
