SailNet Community - View Single Post - Cruising rpm's
Thread: Cruising rpm's
  #27 (permalink)
Old 10-31-2009
Northeaster Northeaster is offline
Northeaster is on a distinguished road
When I bought my 30'er, which has an older (1982) Yanmar 2GM, 15hp max (3600rpm), 13hp continous (3200rpm), it was overpropped., with a 15x10 fixed 3 blade.
The engine "seemed" happy up to 2000rpm - in fact would push the boat to within a knot or so of hull speed, at these low rpms. But, if I tried to give it more throttle, I would get black smoke, and the engine wouldn't sound happy.
After much reading, and talking to a knowledgable prop guy, I had 1" of diameter and 1" of pitch taken off this winter, to make it a 14"x9". The pitch likely made more of a difference, as there was not alot of surface area in the tips. Regardless, I was told that I might see an increase of 200-300rpms, which would still leave me well short of 3600.
In reality, what happended is I can now rev 3200rpms, (a full 1000 rpms better than before), with no smoke, and hit full hull speed (6.4-6.8 kts) consistantly. I suspect that this is because I only had about 8 hp, to play with at the 2000roms range, whereas now, the prop is able to spin faster, and use more available engine hp as well (approx 13hp). Now, the engine sounds much happier (except for a squeal, that is another issue).
I am still a bit overpropped a bit, as I can hit about 200 higher in neutral, than in gear, with a clean hull / prop. I am not sure if I will have it changed again, as I am very close, and 90% better than it was. If I do, I will send it to the same prop guy, as he had 25 years experience working on props of all sizes (mostly commercial) and you could tell that he knew his stuff.
