Old 10-31-2009
btrayfors btrayfors is offline
btrayfors will become famous soon enough btrayfors will become famous soon enough
I think you're probably OK, too. You can't go just by an energy meter to tell the state of charge of the batteries, since these can be way off sometimes. They need calibration and, of course, proper installation.
I'm assuming the 612 was properly installed, with a separate battery voltage-sensing wire and no battery isolator in-line. Also, that you've chosen the proper charging program for the type of batteries you have.
In the absence of a marine electrician, you can yourself determine the state-of-charge (SOC) of the batteries by measuring the voltage at the battery terminals with a digital multimeter, but do so only after the batteries have been resting for several hours with no charge on them and no load on them. I know this is hard to do while cruising, but it can be done, and is the only way to be reasonably sure of their state of charge. With flooded batteries, you can also use a hydrometer to measure the specific gravity of each battery cell.
Please note that NEITHER of these techniques will tell you about the health of the battery, i.e., it's capacity to accept, hold, and deliver energy. Only a load test will tell you for sure, though some expensive devices like the Midtronics testers will give a fair indication.
The MC-612 is a reliable regulator, and as noted can be rather easily programmed.
Do you have temp sensors connected? For the alternator? For the batteries? The MC-612 will take both. Sometimes, the sensors themselves are bad. They can be off in either direction.
Also, the MC-612 preferably should be mounted outside the engine room...it gets pretty hot in there. Not good for any electronics.
BTW, the Balmar DuoCharge has a known problem. If for any reason you try to pull more that the rated 30A thru it, the unit can develop a fault. Balmar knows about this and is reportedly fixing it.
Bill
