Battery Terminal Fuses
The ABYC regs require what amounts to a fuse for the battery itself, thus everything connected to the battery is fused. Check out Blue Sea Systems web site; search for PN 5191 - Terminal Fuse Block, 3/8" Mounting Hole, 1 Terminal Stud. You need the fuse block AND an appropriate fuse module to go with it - make sure it is heavy enough to handle the whole battery load!
Good luck!
