SailNet Community - View Single Post - How do you clean the bottom?
post #3 of Old 01-20-2006
hamiam
If you were to suit up (with a tank) I wud recommend a scotch-brite pad to remove the growth. I wud suggest you google for a product called dri-diver which does an effective job of cleaning the hull while the boat is in the water and does not require you to go into the water. Good luck..
hamiam is offline
