Old 01-24-2006
Petar Petar is offline
Petar is on a distinguished road
Effectively sealing forward hatch
Hi,
I have noted a small leak on the corner of my forward aluminium frame hatch on my Dufour 31 sailboat dripping onto v-berth. Trying to figure out where the leak comes from was not an easy task as marina management have shut the water off for the winter (although we did not have a single freezing day but a lot of rain)so I have decided to take it off, clean and re-insatall back. When I removed the complete thing off I noted that the sealant used was (most probably) similar to 3M 5200 although hard to say whether it was original (boat is built in 1979,or removed and re-sealed sometime in past. When I have scrapped off the remaining bits of the sealant, the deck surface seemed very smooth with small cracks around the holes for SS screw used to secure the hatch in place but no major damage or reason for water to find it''s way into the boat. Now I have cleaned & polished the aluminum hatch, replaced the neoprene rubber gasket between the lower and upper part of the hatch and am intending to put it back in place. I would appreciate some advice if I should only use 3M 5200 marine sealant between the deck and the hatch or I should also insert some sort of gasket made from rubber or even cork (rubber sheets not easy to find in this size).
Petar in rainy Vancouver
