SailNet Community - View Single Post - Rotten core around Mast Step-repair
post #12 of Old 11-03-2009 Thread Starter
superiorvoyager
So even if I go with wood don"t use balsa but use marine plywood. But what is it's advantage over fiberglass? I should mention that I will go in from the top since the deck requires repair where the outer skin cracked due to the compression. As far as the sugestion of stopping into a boat yard or Fiberglass place there are none here. There is a boat yard 140 km away but they don't do this type of repair anyway.
superiorvoyager is offline
