SailNet Community - View Single Post - Rotten core around Mast Step-repair
post #14 of Old 11-03-2009
mitiempo
mitiempo's Avatar
I'd go solid not wood core of any kind under the mast. Stillraining is right - the only reason builders use plywood is that it is cheaper and is also faster than multiple layers of glass. I'd use epoxy (West as I know it well) and rather than mat and cloth or roving I'd use 1708 biaxial - stitched as opposed to woven roving with mat already attached to one side. It's easier to use and fully compatible with epoxy - some mat isn't epoxy compatible. If your deck is already needing repair going from the top is always the best way - it's easier and the job will turn out better. I'd paint after instead of gelcoat. For a good rundown of this see Tim Lackey's site - Northern Yacht Restoration | Tim Lackey:* One Man, One Boat at a Time. He recores decks on a regular basis in his restoration business and documents everything with lots of pics. Just click on one of his projects and follow it along.
Hope this helps.
Brian
mitiempo is offline
