I made my own "stackpacks/mackpack" sail cover/lazy jack system and saved a thousand bucks (I have a 50ft sailboat with 450sqft mainsail). The lazy jack system is built first and then you sew up two vertical long panels that will ride inside the lazy jacks (attached to each down-line to hold up the sides up) tall enough to cover the flaked sail. Actually the long panels are sort of triangular as the part at the end of the boom need not be as large as the part at the mast. I even sewed in a horizontal panel between the left and right side vertical panels that has a long zipper in it. I can zip up the "bag" and the mainsail is totally enclosed and protected from the sun's UV and rain and dirt.
