SailNet Community - View Single Post - 1968 morgan 30 centerboarder
Old 11-05-2009
mitiempo's Avatar
mitiempo mitiempo is offline
ross
There is nothing wrong with a Morgan 30 that wouldn't be wrong with an Alberg 30 or many others. The basic boat is fine if you are pleased with it. I have owned sailboats for over 40 years and if I were you I wouldn't trade what I know for something else that could have more extensive problems. The Morgan 30 is a good sailing boat from what I know, Charlie Morgan was a good sailor and designer. The key will be condition and equipment. If the basic condition is good ( as you say it is) equipment is what you need to sail offshore successfully. That doesn't necessarily mean the latest electronics, but basic sailing gear so you can reef easily and efficiently, cook in rough weather, find your position,with accuracy (gps plus spare), anchor with confidence (30 lb plow or whatever with the appropriate chain and rope rode), in a leak free hull/deck. It sounds like what you lack is confidence and that will come with experience. Go sailing, learn to reef when it gets snotty out there and your confidence in your boat will build. A lot of sailors have cruised far and wide with lesser boats. Every day isn't a survival type of day. The trick is to be the best prepared you can be for that day, and it may never come. While I am not sure where you wish to go, watch the seasons and weather and you'll do ok. Most sailing is done in relatively good weather, but the books are better when storms and survival are paramount. Proper weather and route planning can make all the difference. Hope this helps.
Brian
